Got an idea for a solid mount, wobble free, freewheel drive.
I have a Shimano threaded rear hub that isn't being used for anything & a spare Sun Rhyno lite front wheel w/iso 6 bolt mount & 20mm thru axle.
I measured everything & this will work. I was thinking about cutting the end off of the freewheel hub leaving just the threaded section and spoke attachment flange. The outside diameter of the spoke flange is 54mm and the bolt holes of an ISO 6 bolt hub is 44mm. I'm showing a disc rotor in the pics just to get the holes figured out for bolting to the iso hub on the spoked wheel. Everything lines up including the spoke holes. Those can be used as a pilot hole to drill the 6 larger holes to mount the flange to the wheelhub. The front wheel can then be installed in the fork dropouts backwards (6 bolt to the right). Mount the cutoff flange, thread on an ACS Crossfire flanged freewheel & mount a sprocket (Sick Bike Parts sells them). Just gotta run v-brakes instead of disc since using the disc mount for the freewheel drive.
Too bad they dont make double sided 6 bolt hubs.
See pics
-Lowracer-
See pics
-Lowracer-
