i want to do some performance upgrades for cheap is there any thing i could do to the motor for cheap that would up the power or any other things like exhaust mods. and whats the best cdi jaguar
the cdi should be last on your list. i get my bike up to 40 on the regular with the stock cdi and i have had no issues what so ever with it though i am shure the jag or HD lightning will increase spark substantialy you wont need it untill you got a high comp motor and a freed up exhaust.
first mods should be port and polish and a good port match, this will make your motor rev quicker and rev higher and porduce more power, how mutch power ? eehhh well enough to notice a differance but dont expect a lot with only that as a mod.
second i would ether deck your stock head all the way down to the fins ! take the gasket surface down as far as you can, there should be a fingernail lip for a gasket surface. the stock comp is 6:1 and going with 12:1 doubles it and will help make power all across the rpm range, i etamate a 5% increase in power at 12:1 comp. not mutch but hey every little mod adds up in the end .
you can buy a puch head ... the 70cc hi hi is quite nice and the fred head is top of the line ! also there is the manic mechanic head and a few others
now that your motor is ported and running higher comp you need to buy or make a sweet x chamber exhaust and tune the header length. or you can mod your stock exhaust by cutting it open at the first weld and gutting all the catalitic converter parts and sutch, then drill out the stinger pipe to 1/2 inch or bigger i like 5/8ths. if you want an easy custom exhaust you can make a strait pipe, be shure to use 1 in aluminum tubing and make it TOO LONG ! this way you can ride it and then cut one inch off at a time untill the length is tunned to the rpm you ride at most . this does work contrary to belief and will give you a power band albeit a short band but it will be powerfull where your bands rpm range is .
next is piston mods ... cut the skirt so it does not block the intake at TDC, then if you wish you can grind ramps in the dome to add duration to the transfer ports and exhaust port. also you can lighten up the top end with a titanium wrist pin.
now that you have more power and rev's you have to focus on your gearing ! a shift kit would be ideal but not all of us have 250$ to toss at a HD shift kit ! so you can go with a 40T rear sprocket and gain some speed with out sacrafising torque, you have more HP now so the smaller sprocket wont take away to mutch torque as compared to stock, in fact you may have even more power than stock now even with the smaller sprocket ! if its all out speed u want go with a 36 or 32 t rear but be warned you wont be climbing any big hills though you shure will be fast !
on to the bike itself ! all the power in the world is no good unless you can stop ! you need good breaks ! also rebuild your hubs with good auto grease so they have less rolling resistance and get a good set of tires like maxis hookworms or a clone of that type of tire.
and thats all i can think of now ... keep your carb tunned and properly jewtted also use an NKG plug iridium is best
you dont realy need a bigger carb than stock 15 or 16mm is fine i personaly love the CNS V1 carb and the dellorto sha is great also .
-the cns V1 its a great carb ! if you know how to tune it ! 16mm and fully tunable
-best carbs for the money would be a used cns v1 people do not know how to tune them and they get rid of them for a dellorto sha.
-the dellorto sha yeh its only 15mm but its easy to tune using only one jet and it atomizes fuel realy well so it offers preformance over the stock nt
- the dellorto phbg 16 17 18 19 mm carbs , thease are fullt tunable carbs that require a good mechanic to dial in but they offer unsurpassed preformance !
-the dellorto 16.16mm sha its a 16.16mm version of the sha its an original and there are NO clones of the 16.16 so you will have to dish out 60$ for it but its worth it if you need a better flowing carb for a monster motor and you cant tune a carb !
- the mikuni vm 18mm this is the top of the line mikuni carb for the china girl best preformance you can get for reasonable money !!! expect to spend all week tunning it lol
- other carbs will work too but the ones listed are the normal for the china girl i have seen al the way up to 28mm on thease motors !
