I am installing my Grubee on a Schwinn Delmar. Once the coaster brake arm is off there is a metal cap that I would call a dust cap that sits under the brake arm. It is held on by the brake arm and just appears to be a cap to keep dirt out. On the Grubee kits, does the drive sprocket go on the axle, and then the dust cap and then the brake arm? I put the dust cap on, and then the sprocket, and then the brake arm and once tightened the sprocket seems to be pressing on the dust cap and the brake arm is no longer free to turn. Also, do I need the thick rubber gasket under the drive sprocket? The installation instructions say you may not need it, but it looks like if I don't use it then the sprocket sits almost even with the tire and I'm sure the chain will rub the tire.
Thanks for any advice.
andy b.
andy b.
