Chain length for 50 toot sprocket...
borntofli
306
tx
I have a 44 tooth sprocket now, would I need a new chain for a 50??
Does the length chain with the kits work for a 50 tooth sprocket...???
My friend who weighs 225 wants a bike... figuring a 50 tooth would help him to get going...
Dave31
11,199
47
Aztlán, Arizona
Depends? What bike is it on? Is it a stretch? Did you remove any links for the 44t? If its too short you can always add links.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
As Dave said, it depends. We have no way of determining how long a chain you'll need. Bikes come in various lengths and frame designs. Yes, a 50T sprocket will require a little more chain than the same bike with a 44T. If you're using a chain tensioner you might already have enough chain by removing or adjusting the tensioner to it's lowest position or moving it forward on the chain stay.
Experimentation on the intended bike is the only way to know for sure.
tooljunkie
663
16
Manitoba,Canada
3 more links,depending on how much of the sprocket has chain on it.so,anywhere from 3-6 links,or 3" of chain.
it isnt much,but a real pain if you dont have any chain or links to add.
