put a new carb on my ch80 it will run but when i let off on the gas the motor dies tryed the idol screw with no luck have the crab set on the second notch which is what we are suppose to run them here in thunder bay any help would be great thanks
The last time this same problem happened to me the brass tube that the jet is screwed onto in the middle of the donut float vibrated loose. When I removed the carb bowl that brass tube fell out. Screwed it back in and all was well.put a new carb on my ch80 it will run but when i let off on the gas the motor dies tryed the idol screw with no luck have the crab set on the second notch which is what we are suppose to run them here in thunder bay any help would be great thanks
