I took my first build for its maiden voyage this afternoon, ran well. It is a Micargi The General cruiser. I mounted a 66cc skyhawk, installed disc brakes front and rear, custom chain tensioner mount, clutch cable roller and larger fuel tank. I used a top hat adapter on a cassette hub in the rear in order to mount the disc rotor and sprocket, worked out well. Had to spread the frame in the rear in order to accomadate the wider hub and disc brake rotor. While at it I built a custom chain tensioner and clutch cable mount with a roller. I also had to build a custom motor mount in the front to accomodate the wider frame. Definately fun to build should be fun to ride.
