i have a grubee 2 stroke engine with a pull start and centrifugal clutch. I modified the stock pipe. here is what I did: I cut the pipe open and removed as much of the baffling as i could and drilled the rest of the way through the honeycomb. I then welded another piece of pipe on and welded the cap back on. the pipe is almost the exact same size as it was before. the difference is that the exhaust flows straight through the pipe and has no baffling to go through. It still has a cap on the end and so still acts as an expansion chamber. I dont notice any difference in back pressure, but i could be wrong. i dont notice any difference in power either. my question is, are there any potential long term damaging effects that could be caused by modifying the muffler in this way? sorry for the long post.
