I have an idea, and I need an opinion from someone with a really good understanding of these engines. Ok, here goes......
I assembled a 2 stroke chinese engine with a centrifugal clutch. The clutch failed, and this engine does not operate with a manual clutch at all. The engine came with the centrifugal clutch factory installed. I have decided not to attempt to repair the clutch, so please no questions about it. Here is what I need an answer on. I have another engine with a manual clutch, and I think I can use the pull start on it. Not the centrifugal clutch, it will still be fully manual. But I think I can use the pull start to start the engine in place with the manual clutch disengaged, thereby starting the engine in the neutral/idle position. The pull start will rotate the magnet and the crankshaft, producing spark and moving the piston (at least in theory). If that theory is wrong, I thought I could use the pull start to start the engine in gear, but I would have to hold the back wheel up, because pulling the pull start with the engine in gear would cause the engine to turn the back wheel. So any accurate advice on this subject would be greatly appreciated.
