What is the lowest possible gear ratio that these motors will handle with a shift kit? Kind of a two-part question, like...
I guess what I'm saying is what is the calculation to convert the equivalent rear hub teeth with the standard rag-joint teeth (to get an idea in comparison with the different rag-joint sprockets I've already ridden), and at what point would the motor peak at a top speed and not even be able to maintain it's own speed on flat ground due to too low a gear ratio.
The best example would be for a 26" wheel with an 66cc (80 or whatever you want to call it) motor that's 100% stock.
- What is the highest gear (lowest tooth count) on a rear hub that these motors can push (without loosing enough RPM to defeat the purpose of itself) on flat ground if they've already got going from previous gears
- How does that compare with the standard rag-joint sprocket sizes in total gear ratio (in terms of tooth count)
