I am looking to build some wheels using bicycle hubs and motorcycle wheels, spokes and tires for My MB, mainly to run motorcycle rated tires as speeds get faster and faster I think this thread could help all.
basically this is the info needed:
What motorcycle wheel/ tire combo will give the same height/circumference as a 26 in bicycle wheel ( this is very important to me as Im running a final belt drive if you are using a sprocket you could always go more/less teeth as needed)
Spacing: needs to be able to fit between the stays ( so the narrower the better) the same goes with the front end. Although there is someone making mb forks with 5 inch spacing but I would prefer to find somthing that would fit between the felts.
