That is one of the ideas I had when I first tried to fit the motor. I was going to try and fit those onto the intake and extend it off the side. But I wasn't sure how it would hold up to the road. The metals should bond though. Aluminum wires bond to copper on PCBs and hold fairly well. If you try it and it works let me know.
Solution near at hand. I picked up a 45 degree copper plumbing elbow today that is nearly made to order. I will need to knock out a simple nipple on the speed lathe to clamp the carb onto. I plan to shorten the kit intake, slip the fitting over it (with silicone and clamp, insert and braze the fabricated nipple, and attach carb. The fit is very close. Do I have a shot at brazing copper to the pot metal kit intake?
