F Flathead Member Aug 8, 2015 49 0 6 Glendale az Mar 22, 2017 #1 How to center rag joint ALSO. Can I reuso old sprocket joint?any Senior HELP
Chaz Well-Known Member Jun 3, 2012 1,004 72 48 Vancouver, British Columbia Mar 23, 2017 #2 I'm pretty sure there are some videos on youtube for this which will likely explain it as well as it can. I had to enlarge the center hole a bit with a round file. You should be able to re use the rubber as long as it is intact and not crumbly.
