I'm looking for ways to lighten up the crank and broaden the "sweet spot", I figure the lighter the piston, the broader and lower (depending on the balance) the vibration free sweet spot should be. ANd I got thinking... What is the con rod made of? it doesn't look like aluminum, perhaps iron or steel? Anyway, I got thinking, has anyone ever tried removing the majority of the middle of the con rod (the part that resembles an I beam) or am I just being crazy? I figure with pistons this small and strokes so short, it shouldn't be an issue, but I could be very wrong, but it'll reduce the floating mass on the crank, allowing balancing to not only be easier, but take much higher RPM's to throw the balance out of sync. I figure with ~180lbs max upward or downward forces on the piston, if it's steel, it'll be more than strong enough, if it's aluminum, it may be questionable. My goal is not only to reduce vibration, but also the more RPM's I can get out of it, (my bearings are SKF high RPM industrial bearings, so dont worry), the more speed.
Has anyone ever tried it before? Does anyone know what the rod is made of? Would it be strong enough to hold up to the pressures if you remove the center of the I beam part? (essentially making it a = beam)
