Silent rider
Toffa
11
Australia
Hello,
I have a Chinese generic 2 stroke engine kit, it's 66cc. I would like to make it run as silent as possible, how do I do this? What do I need? Where do I get the supplies from? I would first like to make the clutch case make less or no sound (right hand side case) please help
Thanks,
Toffa:-||
Jul 15, 2009
594
waukegan IL. U.S.A.
Filestyle made some rubber pads (about 1/4 inch thick) cut to same shape as cover and glued down overnight with some weight on it. Works great to cut noise ,easy,cheap.
Have the proper amount of lube on gears cut noise also.
You can also fab a secondary baffle for exhaust can , don't block flow , and point it down and away from bike at angle . Hope this helps good luck
