Heavy drag when pedaling
Bradwood
N.News, Va
Greetings all! I'm new to the forum and motorized bicycling community as a whole having completed my first build just a few days ago. I chose a Skyhawk GT5 kit on a Schwinn Clairmont mainly for the vintage styling. I have "silently" received a great deal of help from this forum throughout the process (on and off for 4-5 days) and the ease of the Google search feature resulting in a nice, clean build that avoided many mistakes I may have otherwise made. Thanks for that!
This particular question comes after a few hours research here on topics similar to but not exactly addressing the problem I'm facing. By the way, the bike works pretty good otherwise and I've followed directions/informed suggestions/sound advice as closely as possible.
I find that the bike is a hard pedal when the motor is off and clutch disengaged, to the point that I've basically lost the bicycle part of it. In 1st and 2nd gear I can get up to speed to start the bike fine but it's put so much drag that I can't take a normal ride anymore, and that's coming from a reasonably fit individual. It feels similar to tightening the wheel bolts too much on a regular cycle to the point where it does not spin freely. I used to cruise on 4th gear without a motor but now even 1st feels like 5 or 6 on the same flat surfaces. I expected the extra weight and chain to feel like a gear or two up from normal, but this is crazy!
I double & triple checked the clutch for proper engage/disengage and it seems to be fine. At one point I adjusted the cable so the arm was absolutely maxed out in the disengage direction (had to leverage it to do so - there's so much tension) and it still pedaled heavy. I even loosened the flower nut over the clutch to increase its travel. Still starts and runs fine with no apparent slip but entirely too hard to pedal with the motor off. I'm getting no indication that the clutch is anything but fully disengaged. Alignment seems to be pretty good with no chain binding issues. I tried loosening the chain a bit via the tensioner but anything other than taught causes the chain to pop off on the outboard side of the 10t sprocket (think that's a tensioner issue - it sometimes acts as a derailleur when maladjsuted)
Any ideas out there? Assuming it is probably not the clutch at this point, I'm left to think that the 10t motor sprocket may be the culprit. I hear a lot of talk about the sprocket in "freewheel" mode with the clutch disengaged but this is hardly like that - it still takes considerable effort to turn it. Could there be anything other than the clutch causing this issue?
Having never ridden one of these before it's hard for me to say what's "normal", but by the descriptions out there this is not!
GearNut
5,104
11
San Diego, Kaliforgnia
That style of freewheel would require a pull starter to be installed on the engine as the freewheel will not allow you to pedal start the engine.
I recommend checking the sprocket alignment between the engine and rear wheel and making sure you have twisted the chain tensioner bracket properly. All stock chain tensioner brackets need to be twisted to allow the idler wheel to spin truly in line with the chain travel. If the idler wheel spins crooked in relation to the chain it will cause the chain to run crooked as well.
If you have to keep the chain very tight to prevent it from coming off, something is amiss.
Also, a very tight chain will definitely play a part in creating the excessive drag you are describing.
Mike B
2,256
7
Central CA
Yeah, they are hard to pedal backdriving the clutch.
That's why you want a real low drive gear and hope you don't break down. For insurance, pack a needle nose in your bag so you can take the chain off if you break down far from home.
The_Aleman
2,653
Yeah, the clutch prolly isn't disengaging quite all the way. Get back at that flower nut!
I rode around a lot with clutch lever locked back in the day, and the extra resistance wasn't bad, was manageable to pedal 10-12MPH for miles.
Also, make sure that pin and bearing on the left side behind the cover is quality greased. It's important!
MarkSumpter
474
Ohio
also remove your clutch cable post and shoot some grease in the post hole to lube the clutch shaft. you can get a 10x1 (if I remember right) metric grease zerk to allow you to grease it easier. if you over grease though you may have to clean the clutch pucks it is easiest to remove the clutch assembly and grease just till it starts to squeeze out the bearing
Bradwood
N.News, Va
Thank you for the responses! I had actually squared away half of the issue since the original post. Of course it did end up being the clutch that caused the excessive drag. What was happening (kind of embarrassing really) was that I did have the clutch fully disengaged when I tightened the cable through the arm, but the enormous amount of travel before the handlebar lever "locks" against the pin was enough to partially engage the clutch again. Ultimately I had to leverage the heck out of the bar on the motor and tighten the cable as far as I could to achieve full disengage at the "lock" position while pedaling. It seems like the amount of tension needed to push the clutch rod is excessive, but I don't see any noticeable defects. The 1/16" free play is long gone but there doesn't seem to be any slip and I can pedal much much better than before.
@Mike B: One of the first pieces in my tool kit was something to remove the chain just incase!
@ The_Aleman & MarkSumpter: I'll make sure the post is greased and if it's not, add some. In what way might that affect performance if it's not well-greased?
On the other hand, the chain still needs to be very tight in order to stay on. I'll need to check into the alignment issues a lot closer. So far I've got just under 60 successful miles on the engine so it does work great, but that chain tension does indicate a subtle problem that will eventually manifest.
The twist you are referring to, is it commonly a vertical, horizontal twist or both? I've had trouble with the tensioner from the get-go. Not so much with alignment (have not twisted it...yet) as far as I could tell but with the connections between wheel and bracket. Wouldn't be surprised one bit if that was the culprit.
Thanks again all!
GearNut
5,104
11
Horizontal twist. The tensioner bracket comes flat. When attached to the chain stay it mounts parallel with the chain stay. The chain stay does not run parallel with the run of the chain. This causes the chain to run crooked through the tensioner wheel.
The tensioner bracket needs to be twisted to correct this crooked wheel angle so the wheel spins true with the chain.
Also be ware of the tensioner! They like to rotate on the chain stay and jam into the rear wheel, locking up the wheel and ripping spokes up.
Do a search on tensioners. It is well worth the time.
Bradwood
N.News, Va
I think I've got the clutch issues taken care of apart from the greasing. I'll do a search on threads that may have answered the question already, but I'm getting an intermittent squeaking noise coming from that 10 tooth sprocket area that's becoming more pronounced and constant.
I'm guessing it needs greasing, do I have to take the whole assembly apart and grease the pin/post and bearing by hand or is there a way of getting to them as is? The end of the post is visible but I can't readily see any bearings around the 10 tooth sprocket area with the cover off. I'm trying to avoid disassembling more than necessary- that's when things go from bad to worse.
As for the alignment issue, I think that tensioner may be a piece of junk. The front and back sprocket seem to be in acceptable alignment but it looks like the tensioner is throwing the setup off. I'm working with adjusting the twist as GearNut recommended but the plastic wheel is wide enough to allow the chain to walk left and right even when it is aligned. I'm going to start searching for a better setup- perhaps one with a spring involved. It seems like the tensioner should have teeth like the pedal chain derailleur.
MarkSumpter
474
Ohio
Brad you can force grease into the clutch shaft and bearings easiest by removing the clutch cable post and inserting a m10x1 grease zerk in its place and then shooting grease to it this will force grease out both outboard bearings. If you over grease though you may need to clean under the clutch and the pucks. After you are done remove the zerk and replace the post and readjust the clutch. I make a right angle cable pull bracket I will be selling in the next month that eliminates the clutch post and then you can leave the zerk in place to be able to grease the shaft as needed without disassembly.
Bradwood
N.News, Va
Thanks for the info on greasing the rod & bearings. I used a good synthetic grease from Advance Auto (think it was called "green grease") which seemed to work well. The squealing noise seems to be gone, though I only rode it up and down the street a bit.
Before writing the thread I did slide the post on the 10t sprocket side out to get a look down the shaft. That's when I saw the ball bearing and realized the shaft that the rod sits in was not greased. When I put the assembly back together today I noticed the rod on the 10t sprocket side didn't seem to seat all the way. About 1/8" more was exposed than before. I used the three screws on the outer cover to seat the rod which made the clutch cable arm rather tight in all directions. I didn't remove anything but the rod (which was just sort of loosely in there to begin with). Can you think of anything that would cause it to sit about 1/8" shallower in the shaft than it did before?
I took a quick test ride up and down my block and the clutch operates just fine engaging and disengaging fully, but that issue troubled me a bit.
Alson333
46
Kankakee Illinois
The hole you seen the ball bearing, is where you put grease in. If the pin is in and working right, it ok. Might of came out a bit with no greas, or something. Im glad you fixed the cluch, or clutch cable, mine did the same thing today, got 150 miles on this one so far and its reving muvh higher, almost broke in. Oh make sure the cabel comes out of the cabel gide on the engine to your clutch arm, one time mune was off and the cabel would rubb at the end of the gide till it wore the cabel, and broke. I took my chain off the back sprocket so I could ride homeusflg
