This bike is not street legal in our area. It is a shop project done for a repeat customer that already owns 2 two strokes and a 49cc four stroke we custom built for him. The basics of the build are as follows: 79cc Predator, governor removed, custom intake manifold, NT carburetor with main jet drilled and high flow filter, oversized kit tank & fuel valve, automotive fuel line & filter, adjustable 4 stroke mount with base plate strengthened and lengthened 1.5" rear mount block flipped, custom 3rd /motor mount/exhaust brace on top, kit throttle & kill switch, full custom 7/8" exhaust fully wrapped, pit bike muffler, mini bike jackshaft plate with 5/8 shaft, Max Torque go kart clutch, mag wheels with direct mount rear sprocket, SUN high volume tires, Kulana frame/fork, C9 gel seat, solid aluminum quill stem, 4" riser bar, foam grips, ultra wide bottom bracket axle and crank, hydragraphics dipped motor tins, front and rear BMX calipers with special pads. Initial testing confirms the gearing is to tall which was expected, I am switching from a 44 tooth rear to a 56 and that should be really close. And it looks like a rear axle kick stand which was my last choice is the only one that fits. Other than those minor tweaks the bike came out nice and rides great. We have a plexiglass jackshaft chain guard not in the pics until we get the mount for it finished.
