arrow on piston
crassius
4,032
158
USA
got in some kits today with top end removed
put 4 together so far & found 2 with piston arrow pointing forward & 2 with arrow pointing back (with locating pins on intake side)
all from same supplier, all seem same as far as other h/w goes, all machined cranks
the point: never look at the arrow (if it has one)
Greg58
5,353
2,575
Newnan,Georgia
I never look at the markings for piston oreintation, I have found as you have they don't always mean the same thing. Installing the piston with the ring end pins toward the intake is what I do also. The one thing I have learned is never assume anything, check for yourself!
2door
Moderator
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
I have found the same thing from the same supplier. I concure about ring orientation. That's more important than a little arrow stamped into the piston.
This is one of those inconsistancies like carburetor jet sizes. I've found them to be nebulous. I never rely on the advertised/stamped or published size. Actually checking the orifice size is the only way to be sure of what you have.
crassius
4,032
158
USA
Yeah, I see a lot of diff markings at the shop, but this is first time with all in one delivery.
