What's your average speed?
What's your average speed/ total weight on the tyres?
  • Total voters
    37
Toadmund
792
6
Saint John, New Brunswick, Canada
Bike: Small Mountain
Engine Size: 66cc
Drive type:chain drive, 44 tooth rear sprocket
Load weight:22.6796kgs+- (50+-lbs) for bike, 75kgs (165.347lbs) for rider
Terrain: flat and with hill at 2.5Deg. sandy compact roadside
Area: semi suburbia
Average speed:40kmh (24.8548 mph)
Top speed: 58+km/h (36.0395+ mph) flat, 63km/h (39.1464mph) downhill at 2.5Degrees.
Mods:
polished head dome
ported exhaust, matched intake/cylinder ports. trimmed gaskets to match holes where cylinder meets bottom end (forgot the term for that spot)
NT carb (not a mod)
Notched cylinder skirt (awesome mod btw)
teflon top- end bearing retainers made from teflon sink washers drilled out and sanded down.
KMH 415 BMX chain
Echo power blend oil
CTripps
1,310
Vancouver, B.C.
Your idling speed is my average:) I understood that an engine should not be idled high enough to propell the bike?
I've not heard that before... might be something to it, might not. I mentioned it because when Harley and I are out for a ride, I usually idle along with her while she has some throttle open (not a lot, she's not a speed freak like I am ;) ). I'm not sure what the top speed on her bike is, it's only just past break-in and she's not one to wind it out the way I do. I think her TS is around 40-45 kph, using the same 66cc but with a 48T sprocket on the wheel (and a bit more over-all load on the motor). If I ride her bike (apart from my knees hitting my elbows when I pedal) it'll pop the front end up if I drop the clutch at high RPMs due to that torque sprocket.
I've always run high idle speeds, years ago when I was a delivery guy my beaters used to be dialed in to idle at around 45 kph, just a little below traffic speed.
(By the way folks, a quick guideline is that 10 kph / km is a little over 6 mph / miles [6.21 if you want to get finicky about it].)
Wild Bill
478
5
Camarillo So. Cal.
Bike: GT LTS Mountain Bike
Engine Size: 69cc Dax F80 W/Rt Carb & SBP Pipe
Drive type:SBP Shift Kit W/9T Output Sprocket, 8 Speed Derailleur
Load weight: Bike-60 lbs Rider 215 lbs
Terrain: Dirt roads, Trails, Hill climbs, Street
Average speed: About 15mph (lots of slow technical trail & hill climb)
Top speed: 35.8 mph on Street- 32.4 mph on dirt
My bike is a tank (60 lbs) for being an aluminum frame, the shift kit is a good part of the weight, Im gonna change that with aluminum sprockets.
Legwon
248
Van bc Canada
Bike: trek motorized bicycle, 26"wheels, 21" frame
Engine Size: 66ht
Drive type:41 roller chain on 50t sprocket
Load weight: Bike-85lbs Rider 180lbs
Terrain: anywhere
Average speed: 29 KPH
Top speed: 52.3 KPH
Mr. Minecraft
Visionary
Jan 13, 2012
349
San Diego
Bike: Felt Slant
Engine size: Hua Sheng 49cc
Drive type: 4G transmission, chain
Load weight: approx 190lb (I have never weighed it :))
Terrain: Hilly asphalt, hard packed dirt trails, grass, loose dirt
Area: Town, neighborhood, trails
Average speed: 21mph
Max speed: 38mph
Happy Riding!
-Chris
fredric3144
110
77
lufkin tx
motor 80cc ? china girl
standard kit chain drive
me 185 lbs
country black top simi smooth
5 min = 2.1 miles 2.1 x 12 = 25.2 MPH
still lots of throttle left I ran it full speed and it burnt out the CDI have replaced CdI and will stay at a comfortable ride at the above average
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Update: Now running 36 tooth and loving it! Perfect powerband with my pipe setup and much calmer cruising. Very nice for flat areas even with a big guy like me!
5-7HEAVEN
2,661
240
Bike-Diamondback Response w/203mm disc brakes, 26.5" Scwalbe Big Apples
Motor-Tanaka 47R 2.8hp w/ 3-piece Tanaka pipe
Drive-8/speed shift kit-46.3:1 First gear, 15:1 Eighth gear
Bike weight-60lbs; Rider-200lbs; Load-20lbs.
Road terrain-flat asphalt w/ two steep hills
Time traveling 6 miles roads, bike path and heavy traffic-20 minutes
Average speed, including waiting for all traffic stops-18mph
Cruising speed-30mph
Top speed- Untestedxct2
Risingsunn
194
8
18
Maricopa Arizona
Most of my details are in my sig
Bike: Gary Fisher Capitola (cruiser/commuter)
Engine size: 66cc HT
Drive type: 415 Workmans chain on a 36t
Load weight: 195 + bike weight
Terrain: Las Vegas urban
Average speed: 26-29mph
Max speed: depends on the conditions 33-37mph
Fuel mix: 50:1 Homelite
Speed carb
Magacor spark plug wire
NKG B8HS
SBP expansion pipe
Approx engine mileage:420
Spoooooky
18
Holiday, FL
Bike: Cruiser
Engine size: 50cc China Girl
Drive type: Chain, 44T sprocket
Load weight: Around 155 lbs / 70kg
Terrain: Flat, all asphalt/concrete
Area: surburban
Average speed: 25 mph (flat)
Max speed: 32 mph
Avalanche
48
Rhode Island
Bike: Cruiser
Engine: 66cc China Girl (no mods, everything stock)
Drive type: Chain, 40T sprocket
Load Weight: Me-155lbs, bike don't know, going to guess 50lbs
Terrain: rolling hills
Area: city/rural
Average Speed: 22-24MPH
Max Speed: 32MPH on a flat
missle3944
51
California
Bike: Cranbrook Cruiser
Load Weight: Me-120lbs, bike don't know, going to guess 50lbs
Terrain: flat/hills
Area: city/rural
Average Speed: 17.5MPH
Max Speed: 32MPH flat
Kioshk
1,152
10
Connecticut
Bike: 29" motorized bicycle
Engine size: 66cc X80
Drive type: direct 56-tooth sprocket
Load weight: 350lb
Terrain: slight hills / asphalt
Area: Everywhere
Average speed: ~22mph
Max speed @ ~7500 RPM:
mapbike
5,502
109
Central Area of Texas
On my Huffy Karaoke I cruise @ 32-34mph
On my Kulana with the Dax Gen IV I cruise at 40-42mph
On my older first build mountain bike I cruise at 28-30mph
Map
.wee.
Mr.B.
1,329
559
Excalibur ‘09
Bike- Made from various antique bicycle/motorcycle parts.
Engine- 1939 Wisconsin model AK (17.8 cubic inches)
Drive- Belts/jack shaft- Slipper clutch
Weight- 220 lbs. Bike only
Terrain- City streets with many steep hills.
Typical cruising speed- 15 to 20 mph
Max speed- 30 mph
Robert Thumper
Bike- 1960 Schwinn cantilever, rear triangle stretched 5”
Engine- Greyhound 200 (200 cc)
Drive- CVT with chain secondary 9t to 48t final.
Weight- Apox 100 lbs Bike only
Terrain- City streets/country roads with many steep hills.
Typical cruising speed- 35 to 40 mph
Max speed- Low 50’s mph
caduceus
173
Frostbite Falls, MN
On a calm day the Auffenauger will cruise at 30 and top out at 35 with a Honda 49cc 4-stroke engine and a 40-tooth rear sprocket. With that gearing it doesn't handle hard headwinds well.
Peerless Leader also has a 49cc Honda 4-stroke and is geared lower with a 48-tooth rear sprocket and will cruise at 20-25 easily in almost any type of wind.
FMB42
107
Idaho
Mr.B, those bikes are really something. I can't tell you how much I like that '09 Ecaliber.
Btw, the average top speed of the earliest HDs, Excelsiors, etc, etc, were pretty much all within the 30-40mph range. You gotta like the fact that many of the reported top speeds on this thread reflect very favorably with that of these early motorcycles.
fredric3144
110
77
lufkin tx
I don't know mine goes faster than I can peddle for any length of time . I haven't found a speedometer that works on my motorized bicycle yet . I have mostly decided it gets me from point A to point B and back so I am happy .
caduceus
173
Frostbite Falls, MN
Excalibur ‘09
Max speed- 30 mph
Robert Thumper
This is a pair of beautiful bikes.
