It's what I have on my CNS, dude.
See here:
http://motorbicycling.com/f13/ordered-good-replacement-filter-my-cns-21642.html
I'm sure you'd have to plug the screw holes if you used it on the standard carb and the lack of a deep flange may cause difficulty in tightening the clamp on it.
If you're unwilling to risk it, keep looking and I'm sure you can find one that has the 2 screws through it, like the standard carb... I'm pretty sure this one could easily be made to work, though. You could even fabricate a flange off of 2 bolt holes or standoffs, rather easily. Just takes a little ingenuity.
I'm very happy with performance and sound, but I think some of the charge kicks back out the filter as the piston is going up and it's leaving some gas/oil mix on the seat tube. Could be the carb not being level and gas/oil draining out the overflow tube on the bottom of the carb, too...
