well not really. I think I am going to build a no pedal scooter. I think I have a good build plan I just need to make a couple of decisions then start building one step at a time.
I have a 600 watt at 24v motor I am not using. I have an axle mount so that isn't going to be a problem. I need to decide on the frame and wheels. Then decide on the sprocket size and get a controller and some metal.
I'm thinking I will get the best hill climbing if I use a 16" wheels. A lot like my old pusher was. I'm thinking build it on a 20" sissy frame. A 16" frame would just be to small. I can ride on a 20" comfortably if I don't have to pedal which i won't.
So if I buy a 20" thrift store bike for under twenty bucks I can use the frame and the front wheel. The rear wheel I can use as a spare for my Rhino bike if it is any good.
Then I need to buy a 16" or `18" bike at the thrift store just for the wheels. Pull brakes on front and one of the rear wheels should work fine. Yes I am going to put two wheels on the back.
The plan is to put the rear 16" wheel on the right side If you are standing behind the bike and the front wheel on the left. I am going to support both sides of the wheels. I will attach one side of the rear wheel's axle to the bike frame using one side of the drop outs. The other side I will attach to a piece of channel to the outside of each axle. Then I will connect the outside pieces of channel through the bike frame in front, and behind the two tires in the rear. I will probably either weld the part that runs through the frame for stability.
With a little luck it will be a very thin three wheeler. Probably a little unstable but then again maybe not too much since there won't be a lot of weight if it leans a little. There might be enough room to place the batteries in front of the rear wheels but that remains to be seen.
Anyway I think that is the plan. Has anyone ever done anything like it.
