Old 07-18-2009, 08:12 AM
captainrichhill captainrichhill is offline
Default Re: working crusier without a tensioner
If you run into using the tensioner again, you can use a small set screw in the side of the derailer to prevent it rotating into the spokes. Just get the tensioner into place and drill a small hole through the tensioner AND into your frame. Then put a sheetmetal screw or something in the hole to keep the tensioner in place. FYI
