Old 12-08-2008, 02:41 PM
jason4207 jason4207 is offline
Default Re: New member needs help w/ 48cc 4-stroke (chinese)
OK...I think I was confused earlier. I think that little thing b/n the gas tank and carb is a fuel filter and not a float bowl. The float bowl is actually part of the carb assembly, and is on the bottom, correct?
If so, and if the line is a drain line, then was it suppose to be broken off? I'll look for the screw to close it tonight. My gas tank cap has a small hole on a nipple. Is that just to allow air in or should a hose be attached?
