Old 03-09-2008, 08:20 PM
Default Re: Ask a specific question
Remove the plug and put the wire on it and turn the engine over to see if you have spark.
The kill switches on most of these are pure garbage, so I'd try removing that first.
Also, check to make sure the wire is screwed into the CDI all the way and while you're at it, make sure the plug cap is secure.
You can always shut it off with the choke or by just letting the clutch out with no throttle.
