Old 10-31-2011, 05:09 PM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: Need help getting it started
Originally Posted by ex42k9j View Post
I have my bike built but I cant get it to start.
using a 20:1 oil/gas. the back wheel cycles through no problem (i can peddle ~ and i know i need to change the master link holder on my chain so the back end of the link is going in the engine first)
I got a new 1/16 ID gas tubing and that solved my leaking problem. I have the choke down too.
are the wires hooked up correctly? is there a spark plug issue?
First thing I noticed is the junk spark plug and wire...change them.
Looks like the white wire is connected to something. Black mag to black CDI, blue mag to blue CDI. Disconnect the kill switch wires and give it a try. What did you do with the white mag wire (cut it off)? When peddling it is the piston cycling?
Looking for HT's parts?
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
