bikeberry vs bicycle-engines?
breezetix
15
11
3
22
Which 2 stroke kit is better? in terms of torque and speed, bikeberry 80/100cc with upgrades/mods, or bicycle-engines with zeda 100 with upgrades/mods? I wanted to get Phantom 85 instead, with upgrades/mods, but which is better?
  • Like
Reactions: fasteddy
breezetix
15
11
3
22
What type of upgrades and mods are you wanting to do?
sorry for late reply but not sure exactly, whatever gets me going fast af. for now i gotta break in the engine, i just built it onto my bike. so gas/oil mix ratio, i'm probably going with at least 20 to 30:1 just for breaking in, then use 30 to 40:1 from now on probably. do i gotta mix the oil in every time i refill the tank? and what kind of oil is good enough? just regular 2 stroke oil?
also, do i have to actually mix the gas and oil, like shake it up or something? or is that not needed, just fill the tank with gas and oil?
  • Like
Reactions: fasteddy
Venice Motor Bikes
Mar 20, 2008
7,274
1,812
Los Angeles, CA.
Yes... It's very important to mix the gas & oil in a SEPARATE container & shake it well BEFORE filling your bikes gas tank.
These 2-stroke engine aren't like 4-stroke engines... 2-stroke engines don't have any oil inside them!
The only oil the engine has to keep from blowing up is the oil that you're mixing into the gas! (so it's very important that you mix it correctly & shake it well before filling the tank).
breezetix
15
11
3
22
Alright, mix in a 2gal or so gas container then? And to refill, shake it up each time?
curtisfox
6,048
3,960
minesota
For years I always mix mine, i by the oil in small jugs 40:1 size, dump it in gas can then go to gas station and fill it up, and shut the pomp off at 1 gal. That alone mixes it, just got to watch the pump so you don't go over or under to much..............Curt
breezetix
15
11
3
22
so, the exhaust bolts were a little loose from vibration, so i went to tighten them up more, one of the bolt broke. and now it's stuck in the thread hole. what now?
  • Like
Reactions: fasteddy
Venice Motor Bikes
Mar 20, 2008
7,274
1,812
Los Angeles, CA.
YouTube is a great place to find tons of info on how to do things like ~ 'properly mixing gas & oil' , 'How to remove a broken bolt' & 'How to use a torque wrench' , (so you don't keep breaking bolts).
breezetix
15
11
3
22
Isn't it like 120 in/lbs (or 10 ft/lbs or 13.6 Nm)? Manual says "1.4Nm (12ft/lbs) for M8, 1.1Nm (10ft/lbs) for M6". It's kinda hard to read those numbers because it's kinda blurred. 1.4Nm would be 1 ft/lbs, 1.1Nm would be 0.8ft-lbs, so I'm guessing they typed it wrong.
  • Like
Reactions: fasteddy
Venice Motor Bikes
Mar 20, 2008
7,274
1,812
Los Angeles, CA.
I already said.... YouTube has lots of videos on how to use a torque wrench... Go there & watch them all until one of them makes sense to you.
While you're there... watch the ones on mixing gas & oil, & extracting broken bolts.
2stroker412
53
35
18
48
You have any pictures of your bike/broken bolt? Some of the bolts that come with these kits are really junky.
  • Like
Reactions: fasteddy
breezetix
15
11
3
22
I got the bolt out and figured out about the mix ratio, but thanks.
  • Like
Reactions: fasteddy
Greg58
5,353
2,575
Newnan,Georgia
Most loose exhaust bolts are caused by vibration, if you don’t have a rear mount on it the nuts/bolts will shake loose. I use removable loctite on all nuts and bolts, they stay in place and can be removed when needed.
