49cc 4-stroke manifolds for NT carbs!
Venice Motor Bikes
Mar 20, 2008
7,274
1,812
Los Angeles, CA.
There is more than one reason to offset your carb with a Z intake...
Your throttle cable needs a smooth cable flow and if the top bar is too tight, you can just move the carb to the side.
Handy intakes when the need arises.
these are 49cc 4-stroke manifolds... (not 2-stroke)
Venice Motor Bikes
Mar 20, 2008
7,274
1,812
Los Angeles, CA.
Ok cool I found it and its on the way.
It dont mention if it comes with the studs and stuff to hold it on so im guessing ill have to purchase that separate. Would you happen to know the stud size? If not no problem ill just have to stop by the hardware store and size it up.
Re-use the stock gaskets & plastic heat spacer (& find some small bolts at your LHS)
HobbyMan
15
Yep, had to use an offset Z for this 4-stroke too.
Personally I like the stock 4-stroke carb over the NT, but again I didn't try a bigger jet in one.
I cant even find one and no clue about welding, still waiting to learn that. Is there anywhere to purchase the z offset mainfold?
