Ok so some pix from the bench.
Lube..... don't leave home without it!
This is the "pacesetter" upgrade.
Re assembly of a ezm q-matic belt drive. Upgraded to a 5" cast iron pulley from the 5" aluminum on the standard ezm.
Big thanks to Wizzkid for making a metal template for drilling holes for mounting the transmission at an off angle. While the template fits this G35 Honda it also fits Briggs, and all of the other popular, larger engines. Keep in mind that the ezm was designed around the 49cc HS engine.
See how nicely the plate scored for the new holes to be drilled!
