Here's the problem, I hope I can write this up properly
Using motorcycle controls for the lights everything was working fine.
Then this last week I noticed when I flick the switch left the rear left only
came on but both front flasher were going and the same results happened
with the right rear worked fine front both flashing ???
All wiring thoroughly protected first shrink wrapped, then encased in wiring
split plastic tube. No breaks, in junction box no wire nuts undone no frays splits
or cracks, replaced flasher module, no change.
Any clues?
P.S. these are manual switches and I haven't but should I use dielectric
grease there?
Any clues?
grease there?
