Carburetors
$9 - 15mm Walboro clone(??), 31mm bolt spacing (will bolt onto your JUG!)
$19 - Runtong (RT) Carb; Semi-auto choke (throttle click-off), no filter.
$20 - Runtong (RT) Carb; Cable choke, includes air filter
$33 - 17mm to 21mm Dellorto PHBG barebones carb
$50 - 19mm Dellorto clone with mounting hardware, filter & various jets
$53 - 24mm Mikuni racing carb
$32 - 24mm to 34mm Mikuni Clones
$10 - Set of 5 M5 jets, varying sizes
$9 - 32mm Foam air filter (for PHBG clones)
$20 - 4pk various size clamp-on air filters
Intakes
$17-$25 - Various intake manifolds and adapters
$65 - RSE standard reed valves
$95 - RSE high flow reed valves, low profile
$85 + S&H - 32mm Arrow 4-petal reed block, 13mm carb inlet
$220 - Custom Arrow 4-petal reed block & jug, 18mm carb inlet
Top End
$40 - Stage 1 GT5 cylinder (PK80 version)
$120 - Stage 2 GT5 cylinder (PK80 version)
$70-$220 - Various Arrow ported jugs and reed combos
$195 - Puch Gilardoni 74cc high power cylinder, no Head (Alt. With head $235)
$150 - Derbi Metrakit 70cc flat reed top end kit
$15 - Hoca Minarelli piston
$60 - CRMachine Stage 2 head (6.0cc) (5.3cc) (7.2cc)
$30 - Puch Hi compression head (Hi Hi version)
Electrical/Controls
$5 - Pair of brake levers with brake light switch, no controls
$7 - Left side brake lever with lights switch & controls
$16 - Lights, signals, kill all in one switch
$12 - Dual brake lever
$9 - Dual brake cable
$7 - SBP NGK Iridium Heat 6 Heat 7 Heat 8 (higher is colder)
$10 - Iridium spark plug, Heat 8
$12 - NGK Iridium Spark plug
$60 - Jaguar v2 CDI (no coil) v1.9 (with coil)
$80 - HD Lightning CDI with Keyed ignition
$30 - "Race" Ignition coil
$12 - CNC multi-position throttle
$25 - Domino deluxe throttle/brake/choke
$6 - 8 color aluminum throttle grips
$60 - 12v internal generator for HT
$10 - SBP High quality fuel petcock
$1.55 - Throttle cable knarp
$4 - 61" throttle cable, no housing, no knarp (in case you need another one)
$500 - Ecotrons small engine fuel injection
Guts
$10 - SBP Engine hardware kit (high grade bolts)
$10 - SBP Head stud kit (M6-1.0) (M8-1.0) (M8-1.25)
$0.60 - Wide exhaust gasket (GT2a/5a intake gasket)
$2.50 - SBP Aluminum exhaust gasket
$10 - 66cc Gasket set
$37 - Ceramic 6202 high-speed, low friction crank/clutch bearings (pair)
$20 - 50pc. 6202 2RS (sealed) steel crank bearings
$10 - 1pc. SKF 6202-2RS C3 crank bearings
$19 - 10mm Titanium wrist pin, 8.5g lighter **danger! high risk of catastrophic damage!** see here for more info
$5 - Light weight silver wrist bushing, 4.5g lighter
$6 - Tomos brass wrist bushing 10x14x13
$15 - Gilardoni Silver racing bearing 10x14x13
Intakes
Top End
Electrical/Controls
Guts
