Sidecars?
Ludwig II
5,071
783
UK
On the plus side, if the wheels and bike are strong enough, you can career around shouting HELLPP!! a lot on two wheels.
fasteddy
7,454
4,920
British Columbia Canada
Interesting side car. It would be a fun build for sure. I'm finding myself drawn to building another sidecar body but just the body while the tri car drags on. The garage isn't overly warm this time of year and the wood working shop is.
Maybe next January.
FFV8
551
16
Spring Valley NV
My little sidehack as it was at the last Grange race:
Articulated, the wheel leans with the bike. Fully adjustable for camber & toe, it handles well for a sidecar.
I wish I had the woodworking skills some of you here have. It really needs a nice body now.
Intrepid Wheelwoman
2,830
61
Hauraki District, New Zealand
Your sidecar frame is articulated, - wow that is so cool. The two outifts I built up in my thirty somethings (Jawa and Honda) were successful and did a lot of miles, but I always wanted to experiment with an articulated outfit.
That's a lovely outfit you've built, - (sigh) makes me feel all nostalgic for my own sidecar days.
Ludwig II
5,071
783
UK
Jawa? I'll get you all misty eyed now.
Parraaannggangangnapooonnggpoonggpponponponponbergunkbergunk-unk-unk-unk-
Ludwig II
5,071
783
UK
I do apologise. I can't do that sound, but I'm told that sticking your head in a tin bucket and screaming really loud for as long as you can to leave your ears ringing is a good approximation.
Intrepid Wheelwoman
2,830
61
It was quite a unique sound Ludwig. Those old 250cc single banger two stroke Jawa engines had a long stroke as compared with modern engines and with the twin exhaust ports as well they sounded nothing like a modern two stroke.
My word they were good engines and easy to work on too. The gearbox was a bit truck-like, but completely solid. It was the only bike I ever owned that needed to be double-de-clutched to shift down through the gears :D
fasteddy
7,454
4,920
FFV8,
I think you sidecar is the cats whiskers. Your metal working skills are at the top so I wouldn't be worried about building a sidecar body.
The only advise I would have is keep it as light as possible. A heavy body tends to pull the bike into the sidecar and is hard to work against while leaning the bike. This is from personal experience. I don't know if you saw the sidecar I built but it's on the thread and there are a whole lot of photos on photobucket of how I built the frame of the body and covered the frame with 1/4" luan plywood, 1/8" will work as well if you can find it.
I covered the luan with strips of mahogany but it could just as easily be covered with very thin body metal or aluminum glued on with good contact cement. A canvas painters drop cloth could be glued on it as well with slightly thinned out white glue and then painted like it was a canvas covered wooden canoe.
Steve.
Ludwig II
5,071
783
UK
Push in and down on the back, it comes up, bruises your shin, and then falls back down again.
On the plus side, you could have hours of fun with strangers looking for the kickstart.
FFV8
551
16
Spring Valley NV
Thanks for the kind words folks. I started with one of Silver State's frame & tank sets. I built the balance of it.
The bike is no lightweight, with the starter / generator, battery & the steel in the sidehack. That is why I went with a hydraulic disc front brake.
Currently I have a 150 quart ice chest mounted on it. Not a proper "car" but it fills the void.
Intrepid Wheelwoman
2,830
61
