well we all know that you can deck your head way down on a piece of glass and sand paper till you get the comp you want. we all know about cleanning up your ports with a dremal. but after you have your desired comp and the port you want there are a few more mods you can do to your stock parts to gain way more torque and power !
1 grind ramps in your piston at the exhaust and tranfer ports.
2 cut 1/4-5/16 off the entire piston skirt on the intake side.
3 drill holes in your piston to lighten
4 drill your wrist pin out from 5mm to 7.5mm to lighten
thease 4 mods will give you a noticable increace in power and torque and will help out with vibrations at higher speeds.
also a link to a wrist pin for the 66cc gt5 that is 58% lighter than our stock one !!! http://juicemotoparts.com/products/light-wieght-titanium-10mm-wrist-pin-for-49-66-80cc-engines.html
