In this age old debate, I'd like to suggest that for our application that the following;
...That being said, design/quality is more important than material used.
...has a
lot more bearing on the subject than out of context "vibration cycle" studies (which also overlooks steel's higher flex rate) - and what suffices for quality & design, what's suitable for the long term effects varies from material to material and ofc application.
Just because it's aluminum doesn't mean it's "bad" just as just because it's steel doesn't mean it's "good" - this is a far too oversimplified view of a somewhat complex subject, one that's often compounded by builder inexperience.
Even "quality" is comparative when both design and application are included - for example even a premium road bike is not necessarily the best choice for the rigors of motorization as it's primary design goal is to be as ultra light weight as possible, many choppers and some cruisers compromise structural integrity for aesthetics and not even all "vintage" bikes can be relied on simply because they're vintage.
All too often folks judge a bicycle to motorize based only on two factors - price and style, thinking the catchphrase "steel is real" will suffice, which overlooks the fact that even steel comes in various grades and types. For example chromoly tends to be brittle and is very challenging to weld properly (more so than even aluminum tubing) so while it's "quality" it may not be the best choice for additional modification & fabrication. It should go without saying a budget mild steel bicycle with sloppy, undercut welds is far more a deathtrap than even a inexpensive but quality aluminum bicycle designed for abuse, one with the heavier beads and additional gusseting such as a mountain bike... and TBH welding/modifying aluminum isn't really all that difficult - it takes slightly more experience than mild steel to weld it well, but not much w/today's MIGs.
It's all about choosing the right tool for the job - and that choice needs to include more than simply budget, style & material bias.
I've both steel and aluminum motorized bicycles and TBH I've not really any greater preference for either material as they both have their advantages & disadvantages.... but after well over 15,000 miles riding both I can say aluminum is more subject to chafe damage (panniers/cables etc) while steel is corrosion prone and flexy, but as long as you've chosen a stout frame design with quality welds and you've built it properly I can assure you vibration rate is
not a serious consideration in our application... but if you cut corners w/a sloppy, cheap build - even steel isn't going to be enough to save you
