Hey Everyone,
I wanted to ask for some help from you guys with ideas on repairing my frame. I home-built this frame using 1 1/8" inch tubing for the top tube, cross bar and bottom tube. All the joints were interior lugged. I developed this crack in the bottom tube in between my rear motor mount and the bottom bearing bracket. That's the first picture.
The second picture is of two drawings I did for repair ideas for this crack. In the top drawing, I would use a sleeve that is 5" long or so to repair the broken tube. In the bottom drawing, I would use a much longer tube as the repair sleeve. It would join near the bottom bracket and then again on the bottom tube nearer the head tube.
I am making all the joint welds using an acetylene torch and brazing. I am not a frame or welding expert by any means, so I am completely open to suggestions regarding more gusset work or any other engineering addition to make this area of the frame stronger.
Thanks in advance for your opinions,
Gilbert
Gilbert
