So after months of wanting to do this, and after fixing the mount after the cheap bolt broke off inside the engine, I've finally got my motorized bike just about ready. Everything's about in place, except for one problem. The clutch doesn't function!
Now from what I understand, the clutch arm is supposed to push a pin through the engine against a ball bearing which pushes another pin that disengages the clutch. Please correct me if I'm wrong.
No matter how much I tighten the wire controlling the arm, the clutch just doesn't want to move. I've even taken a screwdriver and pushed it through where the pin is supposed to go and nothing seems to happen with the clutch. I have the cover off on both sides of the motor and I can see that the clutch itself isn't moving.
I decided to try and take off the clutch and examine what's going on, but this is really hard when I can't even disengage the clutch in the first place! I removed the little screw and tried to remove the flower-nut like in all the videos, but it won't budge! Should I force it?
I bought the kit from rawmotors.com. Everything seems to work just fine except the clutch and the fuel valve(which leaks gas). I've looked all through youtube and everyone seems to be getting the clutch to work fairly easy.
What should I do?
What should I do?
