The rear bearing [ 10t sprocket side] is starting to wear. Called up Bicycle-engines.com to order a replacement. They sent me two?? identical bearings that do not fit. I used to have a 4g trans and the bearings look like the 4g which use two of the same size on the out put shaft. Jeremy is no longer with bicycle engines and the new guy is out on medical and is not that informed I'm asking if anyone knows which bearing that is listed on the link below is the out put shaft bearing.
Gear Box Assembly
Thanks in advance for any help
