Needing a drive roller for my last build, I began to look for something I could build "in house" easily. Looked at all kinds of things but came up with this, a rubber roller. It can be made in any size you have a hole saw for, just start with a saw 1/8" bigger than the roller size you want. Ebay is an excellent source for sheet rubber, I was about to buy a 1/2" thick sheet when I remembered I had a scrap of horse stall mat from Tractor Supply I had cut to fit my truck bed. It is 3/4" thick so three discs were needed for the 2.125 tires on my bike. I quickly hole sawed 3 discs. Since there were going on a 5/8" crankshaft I then drilled them to 5/8 with a blade type wood bit. Just drill to whatever crank size you are using. The drill leaves the rubber undersized some what, so the fit on the crank is very tight. I obtained 4) 9/16" flat washers from Ace. The hole in them is exactly 5/8. These are used as back-ups/spacers. I also bought a 5/8 clutch collar while at Ace. This fit over the end of the crank and travels inward as the bolt is tightened to compress the discs. Thats it! the crank rotation tries to tighten the bolt so you never have to worry about it coming loose. This set up fits a standard industrial type engines 2.5" long crank. There is just barely enough crank with this size roller to engage the washer and clutch collar. With narrower tires not as many discs will be needed and probably more washers to get the discs centered over the tire. Once set up a replacement roller can be made in 5-10min. So far I have about 65mi on the roller, and it still measures it original 2" diameter, and that includes some riding on sand/gravel. The disc with the small hole has not been drilled to crank size to show the difference.
