Drill press 49.99
chainmaker
2,634
69
48
Ma USA
Harbor Freight has a 40.00 coupon out for this drill press. Its regular price of 89.99 with coupon its 49.99 coupon number is [FONT=&quot]65431371[/FONT] Just thought Id share it.
biknut
6,632
411
83
Dallas
I've had one just like it for about 3 years. I paid $50 at Harbor Freight. It's worked well for all my small part drilling. Well worth the price.
BarelyAWake
7,194
21
Maine
It looks a lot like the Craftsman I've got - so much so I almost think it's a clone... if it is, it's a sweet lil press that'd do ya well, perfect scale fer these MBs at about a third the cost.
Goat, the large top cover w/the lil peg on the side looks like it's the same as others of it's size - in which case it's prolly a five speed pulley & belt system under there *shrug*
Dave31
11,199
47
38
Aztlán, Arizona
I have that drill press got it a few years ago at that same $40 price. Been a great addition to my little shop at home and use it often.
You can see right behind my seat to the left of my tool box that only holds MB parts for building.
biknut
6,632
411
83
Dallas
Does it have variable speed? If so what rpm's?
Like others said, it's a 5 speed.
Even though there's 5 speeds available I run mine on a middle or lower speed because it's not real powerful and it's easy to lock the drill bit up on high speed if you're drilling a big hole. But hey for $50 it still beats the heck out of drilling a crooked hole by hand lol.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
38
N.M.
I was thinking about some work with holes saws if it is not powerful enough for a 1 1/2 to 2 inch whole saw then I am a little discouraged.
BarelyAWake
7,194
21
Maine
It will (ifn it's as like mine as it looks), if yer doin' metal - then it's jus' a matter of usin' a touch of cutting fluid from time to time and keepin' the RPMs down as low as they'll go (normal for metal drilling).
Problem is, even at it's lowest speed it's a touch fast for metal working... but it does OK.
professor
500
Buffalo ny area
Any hole saw you use should go REAL slow.
The slower the better.
I just looked at what I use, and at the lowest setting it is 180 rpm and that is what speed I use for hole saws. Plus a spray bottle of water to cool the cutter.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
38
N.M.
I will prolly get one seeing its all I can afford gotta think about the size work I can get on the table.. I am going to use this with a fully adjustable table vise with up two a 4 inch hole saw on metal as a poor boy machinist on steel and aluminum. . No stranger to cutting oil here. I use it like its no object! Thanks for the input. The compact size of this thing really has my fancy!
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
24
38
Ridin' inSane Diego, CA.
I've got a Delta that's a notch above that one.......wouldn'nt be with out one. Just get a decent drill vice too go with it and you can do many things like drilling round bar stock and tubing safetly. Loves me drill press!
biknut
6,632
411
83
Dallas
If your planning to drill many 4" holes I'd probably recommend getting a more powerful one.
