NEW Crankset with 28t board tracker style front sprocket ($30 retail). 140mm short for use with wide 4 INcludes New BMX Bottom Bracket Conversion Kit so you can use this 3 Piece set on an American style 1 Piece bottom bracket hanger ($20 retail), plus NEW EXTRA WIDE Spindle 158 mm ($10 retail). 158 mm offset bottom bracket spindle for use with 74 mm bearing spacing bottom brackets or when using our bottom bracket adapters. This offset design is excellent for use with pull starters or to provide extra clearance for tuned pipe installations or any other time when a little more clearance is required between the pedals. $45 shipped or delivered in LA
NEW 1 gallon long in-frame Fuel Tank Black. Cap, stud and nut included. 16"(L)X4"(H)X3.5"(W) (the cap and stud not measured) for under bar or rear install use ($40 retail & very hard to find - sold out at most shops). Why spend $300 on a custom in-frame tank? $30 shipped or delivered in LA.
