I noticed this the other day while doing my pre-start check. I pulled the bolt out and it appears it broke off somewhere inside the actual engine block. I have not done anything with it. Any tips on how I should proceed or what I should do?
What I meant is that it appears to be broken off right at the point where the motor housing meets up with the bracket that holds the motor to the frame.I don't see how it could be in the motor.
Back to the original question of a broken bolt. I had this happen as well. I couldn't get an easy out to work so I had to drill and tap which was kind of a pain. Afterwards I read other posts and hindsight...If you have something to grab on to with pliers then great if not, I might suggest to use a dremmel. Cut a slot in the top of the screw to fit a flat head driver and see if you can unscrew it. Us some PB blaster or such to wick into the threads and loosen it up.What I meant is that it appears to be broken off right at the point where the motor housing meets up with the bracket that holds the motor to the frame.
Thanks Norman, I'll remove the other bolt and pull the bracket out and see where the bolt snapped off. Hopefully you are right and there's enough bolt sticking out for easy removal. If not, I'm sure I could find a left-handed bit online (great suggestion by the way, thanks).
Good tip - an improvement on that I've done more than I care to remember is to place a nut over the broken stud and fill it with the welder - then jus' use a wrench to pull out the "bolt" you jus' madeThe case is aluminum...the stud is steel. Grab a mig and build the stud up until you can grip it with a pair of vice grips. Unscrew stud and continue about your day. Easy Peasy.
