Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
How to mount exhaust muffler for no peddle hit
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I always had a problem with having the muffler and cranks touch, so my brother told me what they do ...
Old 07-13-2009, 10:09 AM
Default How to mount exhaust muffler for no peddle hit
I always had a problem with having the muffler and cranks touch, so my brother told me what they do in car manufacture and repair. To make things fit, all you need to do is take a mallot and make a dent in the spot where they touch. This photo shows the half milimeter gap between crank and muffler after the fix.
Old 07-13-2009, 11:33 AM
2door's Avatar
Default Re: How to mount exhaust muffler for no peddle hit
HT,
You can also bend the pedal crank. It looks as if yours is already bent but in the wrong direction. Remove the pedal and use a length of pipe over the crank to apply leverage. bend it just a little at a time and slowly until you get the clearance you need. Hope this helps. You also want to be careful hammering on that pipe if its attached to the engine. You could damage the cylinder beating on it. Be careful.
Over Youth and Skill
Old 07-13-2009, 11:38 AM
TerrontheSnake's Avatar
Nailed it!
Old 07-13-2009, 05:39 PM
I took the pipe off and struck it on the work bench with a lead mallot. I'd rather dent the pipe than risk ruining the cranks by bending those.
I had no other way of securing the muffler to bend it off the bike, so I did this. Works well with no adverse effects on engine performance.
Old 07-13-2009, 09:19 PM
Cabinfever1977's Avatar
i use shorter peddal cranks to clear,but i like your idea of wacking the muff too.
Old 07-14-2009, 07:44 PM
I used a torch to heat up the exhaust pipe then I bent it just a little, so it would no longer touch the crank.
