I thought I better start my own thread on the slant plug (high compression) head. By no means am I complete with this yet, so the writing will appear blogish.
I want to emphasize from the start, for $22 (delivered) this is not a plug and play bolt on, despite the web appearance of such. I think for the price it's a bargain. It looks like it has a nice squish band with a very compact combustion chamber. This must be the "advantage" vs. a regular hemispherical head - although interestingly I think a hemi head with a smaller chamber and squish band might really be the kat's meow. The slant head is smaller, and looks cool with plug laying at an angle. The visual appearance of the head is a little rough. Not complaining, but the mating surface did not look perfect.
Bolt on? Of course, that is exactly what I did. Took the old head off, threw a new gasket on, torqued the slant head on to 15 ft. lbs, screwed in a BP5HS. Bike fired right up, but I could really feel the clutch slip and the raised compression. Took off, but it seemed rough, clutch would slip when I changed gears - but there was a feeling of increased power and all the power, the power band, graphically looking at the power vs. rpm, seemed to come on at some much lower RPM and above that RPM there was very much a flattening and a drop off of power from the peak. The clutch slip was getting worse and very irritating.
Rode back to the shop. Messed with the clutch way too much. (separate thread)
I changed to a cooler plug without the extended tip (B6HS)
Retorqued the head. Rode for awhile. Felt better. Then I notice the head is leaking right in front (engine NEVER had a head gasket leak before). So I take it apart, aluminum paint a new gasket, reassemble and torque to 17 ft. lbs. Rides OK with the exception of clutch issues again. Only notice a slight throttle issue, so I move the e-clip up a notch. Makes a nice difference, seems to be dialed in now. Will check the plug soon.
So while messing with clutch again at the end of the day yesterday I look at the front of the head/gasket seal - it is goozing BIG TIME. So tonight I will pop the head again and check it for flatness as I should have done twice before!! Arggh.
