Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Polishing the Bicycle Engine
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. The finish on the Happy 2 stroke engines can be greatly enhanced with a little polishing. Here is what you ...
Old 02-18-2008, 06:56 PM
Autocycler's Avatar
Post Polishing the Bicycle Engine
The finish on the Happy 2 stroke engines can be greatly enhanced with a little polishing. Here is what you will need:
-Sandpaper, one sheet of each of the following (wet or dry sandpaper works best)
60 grit
220 grit
500 grit
1000 grit
1200 grit
-one can of clear coat (Rust-Oleum gloss clear works well)
Here's how to polish the engine parts:
Begin with the easiest parts....
Remove the right side clutch cover, magneto cover, and small sprocket cover
Beginning with the coarsest sandpaper (60 grit), gently sand the surface and sides of each part in one direction until all of the oxidized aluminum is removed and surface is smooth.
Repeat with the 220 grit sandpaper, sanding perpendicular to the direction you previously sanded. This will help to remove the scratches made by the course sandpaper.
Do the same with the 500 grit sandpaper, again changing direction of your sanding to progressively remove the scratches.
Now gently sand the surfaces with the 1000 grit sandpaper until the parts begin to really shine. You may choose to sand under running water to remove the aluminum dust and to polish out any rough spots.
Finally, go over the parts with the 1200 grit sandpaper until all of the scratches are satisfactorily removed. I like to leave some scratches to give the parts a brushed aluminum look.
Wash and dry the parts thoroughly. They should be silky smooth and shiny.
To preserve the shine and prevent oxidation, apply two coats of gloss clear coat to the front and sides of each part.
TaDa! These parts should look terrific.
Now, you can either paint the remainder of the engine black or silver. If you are really good at this, you can try sanding the entire engine.
Here's the best part. If your engine dies, you can remove these polished parts and put them on your next engine
I'll post some before and after pics soon.
BY the way, use a face mask if you have one...inhaling aluminum dust isn't very good for you.
Old 02-18-2008, 07:17 PM
CRUISER's Avatar
ADMINISTRATOR
Default Re: Polishing the Engine
awesome, can't wait to see the pictures. i was thinking of doing this but wasn't sure how it would turn out. nice post!
Old 02-18-2008, 07:33 PM
Autocycler's Avatar
Check out the polished components on the Derringer Cycles bikes... derringercycles.com
I wanted to replicate the shine on their engines, and it turns out to be very easy to do. The engine polishing at least
Old 02-18-2008, 07:36 PM
CRUISER's Avatar
ADMINISTRATOR
that does look sharp. wonder if it would be ok to use a palm sander on it
Old 02-18-2008, 08:38 PM
Autocycler's Avatar
I haven't tried it, but I bet it would make things much easier. I'll give it a go on a few parts and report back the results.
Old 02-18-2008, 08:42 PM
CRUISER's Avatar
ADMINISTRATOR
thats what i am thinking. its winter and lots of snow here so i can't ride. gonna try one of the covers this week
Old 02-18-2008, 09:26 PM
nogoodnic's Avatar
I personally haven't tried it yet myself. I do have a polished engine that was done by Kevin (Mypetelvis) it is beautiful. I havent found a project worthy of it yet so it is on display in my livingroom. Those Derringers are some great looking bikes, thanks for the link...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 02-18-2008, 09:35 PM
Autocycler's Avatar
Nice engine. I plan on painting and filing the fins like yours. I'd hate to get that engine dirty
The Derringer bikes are pretty sweet looking. The $3500 price tag seems a bit excessive. Do you have any idea what motorcycle the gas tanks are from? Cafe racer maybe?
  #9 (permalink)
Old 02-18-2008, 09:50 PM
nogoodnic's Avatar
I'm thinking it a moped tamk similar to a Tomos...Kelly
  #10 (permalink)
Old 02-18-2008, 09:58 PM
nogoodnic's Avatar
BTW, I noticed on thier site that the engine is listed as a 49cc 4-stroke. I don't know if they are selling somthing diffrent than the whats in the pictures but that ain't no 4-stroke...Kelly
Similar Threads
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
