| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Clutch won't disengage! STUCK IN NEUTRAL! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I just got my engine back. Had it to the machine shop to get broken studs removed and new ones ...  |
04-18-2009, 05:44 PM
| | Motorized Bicycle Member | | Join Date: Oct 2008 Location: Pennsylvania, USA
| | Clutch won't disengage! STUCK IN NEUTRAL! I just got my engine back. Had it to the machine shop to get broken studs removed and new ones put in for the rear engine mount. When I got it back the clutch won't disengage, and it's making a grinding noise.
I took the clutch cover off and what I saw is in the attached images. The closeup image is with the spring removed.
Anyone know what's wrong? What parts I need? Also I looked at the inside of the clutch cover and it was all scraped up... it appears that the spring was rubbing against the cover. I don't know how the clutch works exactly so I don't know how to fix it. Any help will be greatly appreciated!
Thanks... I know SOMEONE here knows what to do!
Justin |
04-19-2009, 12:02 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: CT, U.S.
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! there is a small screw that holds the "flower-nut" I can't see it in pics.
Norman posted this; http://motorbicycling.com/f30/motor-...lutch-301.html
__________________ Quote:
Originally Posted by NEAT TIMES looking In The Sky, May See Dan Flying By!! Ha Ha Ron | I want 2 ride my bicycle
04-19-2009, 05:33 PM
|  | MANIC Mechanic | | Join Date: Sep 2008 Location: Clearwater, FL
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! Dude, Your pressure plate is missing!!!
How did that happen?
Jim |
04-19-2009, 05:34 PM
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! Oh yeah, I forgot to mention, it also looks like your star nut is dinked up real good!
Jim |
04-19-2009, 05:37 PM
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! Ummm, what is that sitting at the bottom of the frame tubes in the first photo...It looks like the pressure plate.
Jim |
04-20-2009, 09:44 PM
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! Quote:
Originally Posted by Creative Engineering Ummm, what is that sitting at the bottom of the frame tubes in the first photo...It looks like the pressure plate.
Jim | Yeah, that's it alright... it got stuck there under the engine somehow and i couldn't find it. Ehhh... it's been a long work week.
Now I have a few new problems.
1. What is the correct way it is supposed to go together? Does someone have an exploded image of the clutch so I could get it put back right and properly adjusted?
2. Where could I get a new star nut if it needs to be replaced?
Thanks for the help!
Justin |
04-21-2009, 08:52 AM
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! Here ya go:
The cases look a little different than yours, (because this is a new engine I'm making), but the clutch assembly is the same.
Jim |
04-21-2009, 06:13 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Seattle
Jim |
What's that funny feeling inside of me? I'm all tingly, and kind of out of breath..
__________________ www.firebellycycles.com
Visit me and my bikes at Sports X in Seattle, WA
1978 Vespa Grande, 1977 Mobylette 50L, 1980 Garelli VIP, 1959 Tote Gote Model B, 1961 Tule Trooper, 1963 Homelite Trail King, 1980 Yamaha XJ650 1985 Schwinn Sierra with 67cc/SBP Shift Kit/Pipe |
04-21-2009, 08:01 PM
| | Re: Clutch won't disengage! STUCK IN NEUTRAL! wow, thanks Jim... that was EXACTLY what I was looking for. You didn't just make that image up did you? You're pretty good if you did. Anyway got the clutch together and its working properly finally. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:48 PM. | | | Sponsors
