| Sponsors
| Our Forums | | | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | 6 Volt Light Question... Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. In my China Kit, I have a White wire that's supposed to supply 6 volts for lights. I have a ...  | |
05-06-2009, 09:26 PM
|  | Motorized Bicycle Senior Member | | Join Date: Apr 2009 Location: Illinois
| | 6 Volt Light Question... In my China Kit, I have a White wire that's supposed to supply 6 volts for lights. I have a few questions about this, cause mine doesn't seem to be working right.... if at all.
First off, how much Amps or Watts are provided by this 6v lead? I'd like to add 2 headlights, 2 tail lights, at least one Brake Light and hopefully some Turn Signals too. This is probably too much for that lead to provide, right?
Would it help if I added a small Motorcycle Battery as well? The Battery could power the lights when Idled down, and take up the slack from the weaker generator built in. I think. But again, does that 6v lead give enough power to recharge a battery? Or should I just count on needing to recharge that after every other Ride or so?
Second Question. My Neighbor buddy got some lights that run off the older Generator sets from years ago that is powered off the front wheel. He hooked them up to the white wire, and they work A-OK. I bought a Tractor Implement 6v light to connect to that lead, and it don't work at all. In fact, it's basically a Dead Short when hooked up and I have no Ignition for the engine either.
The Tractor light is a 30 Watt lamp. At this point, I'm thinking that the lead will not give enough power to run a 30 watt light.
I tried taking a Voltage test of that white wire, and get Nothing on the DC setting of the multi meter. When I switched the meter to read AC volts, I got 6 to 9 on the meter. What???
Now I am thoroughly Stumped!!! What am I missing here on this? |
05-06-2009, 10:46 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Top of NY
| | Re: 6 Volt Light Question... the white wire puts out around 6volts 3watts 0.5amps
thats maybe good for 1 small light.(maybe a couple leds)
cheap batterys$18,cheap charger$20 and very cheap lights$6: walmart
i use a 18v rechargable cordless power tool battery to power 12v car dual clearance light and 12v car red tailight,hooked up in series=24v with fuse and switch.lasts for many hours,weighs 1 pound,recharges in 1 hour,can use any car or trailer lights found anywhere.if you use small lights you can hook up many lights.
or you can use electric bike battery packs,but they are a lot heaver(25lbs).
05-06-2009, 11:02 PM
| | Re: 6 Volt Light Question... if youre burning bulbs because the voltage goes between 6-9volts:
Modern halogen lamps have a Zener diode voltage limiter built into
them
headlight 6 volt, 2.4 watt bulb and 6 volt .6 watt tail light bulb
05-07-2009, 12:03 PM
| | Re: 6 Volt Light Question... you could check out one of my lights. in the swap and shop
You won't be able to run much on the white wire 1 headlight and 1 taillight.
The voltage is ac and the voltage goes all over the place. Some bulbs will work for a while until they take a spike of voltage/amps/watts or what ever then burn out. I know I have a box full of failures. I have bulbs that will work and not burn out.
These are first a bicycle, engine assisted and not a motorcycle or moped and if you assemble and maintain your bike it will last, get you home every time even when you run it out of gas.
I have also found that some bikes mag coil are not up to the task of running lights very well most will.
The people making the mag coil windings sometimes cut corners. they skip on the amount of turns to make it work good.
Norman
05-07-2009, 08:51 PM
| | Re: 6 Volt Light Question... Thanks for the replies, guys.
Cabin, I'm not burning any lights out, the Tractor Light just won't come on. Being a 30 watt bulb, I thought it was too much. You confirmed that with your first reply. You also confirm to me that a battery is a good addition. I was thinking about a small Motorcycle 6v battery, like the one I had on a Suzuki 400 years ago. Maybe the coil wire (white lead) would do Something to keep a charge up on that, but if not than a regular charger should do the trick, huh? Otherwise, I like the idea of just going up to 12v lighting. I have had a HECK of time finding any 6v bulbs anywhere... even at the farm supply stores! I should be able to find a Motorcycle 12v battery that weighs in at a lot less than 25 lbs.
Norman, Thanks for the confirmation regarding AC voltage. I thought I was loosing my mind when I first saw the readings I got. No I know I was right after all.
Question I left out of the first post I had. What Lights to get? Especially true now, seeing that the lead gives out 6v AC. Hmm. Do DC lights even work on AC? (IF I can find any 6v bulbs, that is) I guess a simple lamp can work both ways as long as the voltage and wattage are correct. This again proves that 30 watt tractor lamp useless in my case.
Another question now, assuming AC power coming from that white wire lead. If it's an AC power source, is the ground (as said in DC) or the Neutral (as stated in AC) wired the same way on these bikes? In other words, can I use the frame as the Ground/Neutral?
Also, can an AC power source work as a charger for a DC battery? It should seem to me that I'll need a converter in this somewhere along the line. I think I'm coming closer to understanding what I need to do.... but will confess that I ain't there yet. Thanks for the replies so far, but I think I need some more Teaching here from y'all.
Norman, can you give a link to one of your lights? I'm new here, and am not aware of the Swap and Shop that you mentioned. Thanks. And I know it's just a Bicycle, but I'm doing my darnedest to make as much of a Motorcycle as I can. I gave up the real motorcycles 12 years ago, and just want to make a comeback to Riding as I can... on the cheap. Even my daughter asked "Why don't you just buy a Motorcycle?" Well, she doesn't realize that I gave them up back when she not even born yet.
I guess it's personal, but I gave up the real cycles for a reason back then, and am just wanting to get a little back into it again with the motor bicycle. This is why I want the lighting to be just right. |
05-07-2009, 09:52 PM
| | Re: 6 Volt Light Question... Norman,
I think I found your topic on the lights in the Swap and Shop.
Is this right? http://motorbicycling.com/f23/lights-7306.html
Reason: yes thats the place Norman
05-07-2009, 10:25 PM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Ontonagon County,Upper Michigan
| | Re: 6 Volt Light Question... Cowboy Rider, EBay has 6v light bulbs and they're cheap too.
Don't feed the bears....
05-08-2009, 09:41 PM
| | Re: 6 Volt Light Question... if you use a motorcycle battery,use a motorcycle or car battery charger.
if you use a cordless power tool battery,they come with a charger or they have one availlable in the same isle near the batteries and tools.if you use a electric bike battery pack they have a charger available for them.
my 18v battery weighs 1lb or less and last for days and cost around $18 and i have a 1hour quick charger.
05-09-2009, 04:43 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: "the bog" NH
| | Re: 6 Volt Light Question... Quote:
Originally Posted by Norman I know I have a box full of failures.
Norman | Quote:
Originally Posted by hiker472 Cowboy Rider, EBay has 6v light bulbs and they're cheap too. |
hmmmmmm...........
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!! |
05-09-2009, 11:01 PM
| | Re: 6 Volt Light Question... LOL! Ozzy.
This is why I don't shop on Ebay!  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:05 AM. | | |
