Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits Classic posts from all the other forums on building, repairing and modifications to your motorized bicycle engine kit.
installing carburetor on manifold of your motorized bicycle engine
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. Easy way to make a leak free carb to intake manifold. Light coat of silicone rtv on intake manifold but ...
Old 01-16-2008, 06:56 PM
Norman's Avatar
LORD VADER Moderator
Default installing carburetor on manifold of your motorized bicycle engine
Light coat of silicone rtv on intake manifold but do not get the stuff on the very end of the manifold you don't want it in the carb.
Take your carb and push it on the intake manifold and just as you get it almost all the way on twist it a little and try to line up the casting seam on the carb with the casting seam on the manifold. While holding it in place tighten up the carb mounting bolt. You can ride it now or wait a day. To check for a good seal while engine is running spray the seal area with carb cleaner or starting fluid a change in rpm will mean you need to do it again which I have not had to do again as it worked every time so far.
Norman
Similar Threads
Motorized Bicycle Carburetor install and rebuild Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 19 02-11-2008 07:19 AM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
installing carb on manifold Norman Bicycle Engine Kits 0 01-16-2008 06:56 PM
tips for long motorized bicycle engine life CRUISER Bicycle Engine Kits 3 01-12-2008 06:24 PM
Motorized Bicycle Engine Oil - 2 cycle Pre Mix Pablo Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 0 12-29-2007 03:38 PM
