| | | Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits Classic posts from all the other forums on building, repairing and modifications to your motorized bicycle engine kit. | Animated view of the HT Clutch Assembly and countershaft Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. This is a multi-part post.
It contains a series of animations that depict exactly what is inside the in-...
06-17-2009, 10:45 PM
|  | MANIC Mechanic | | Join Date: Sep 2008 Location: Clearwater, FL
| | Animated view of the HT Clutch Assembly and countershaft This is a multi-part post.
It contains a series of animations that depict exactly what is inside the in-frame Chinese 2-stroke engines; as far as the clutch and countershaft are concerned.
At the bottom of each post there will be a still of the exploded assembly.
Some of the parts shown will appear slightly different, as these are parts that I make. The countershaft and clutch assembly are shown exactly as they come from the Chinese factory.
Jim
06-17-2009, 10:58 PM
| | Re: Animated view of the HT Clutch Assembly and countershaft This animation shows the clutch components and the order of assembly. The final step in the animation depicts the Countershaft gear and hub assembly. The hub, and bearing race are pressed together to trap the gear. The I.D., (inside diameter), of the gear is actually the outer race for the bearings shown...The gear is hardened. If this press fit is not done correctly the inner race, (with ball bearings), will walk off of the hub...The bearings will fall out and the gear will no longer be supported about the hub concentrically.
Jim  |
06-17-2009, 11:05 PM
| | Re: Animated view of the HT Clutch Assembly and countershaft This animation shows the components that make up the countershaft. For clarity the cases and countershaft are the only items shown.
The slide action that passes through the countershaft is very simple, and effective, by design.
Jim  |
06-17-2009, 11:16 PM
| | Re: Animated view of the HT Clutch Assembly and countershaft This final animation shows the "Action" of the clutch from the actuator to the right side.
It is a partial cut-away...If it ends up being too confusing I will redo it. I'm used to looking at this sort of stuff daily.
EDIT: You will notice from this animation that the total action of the assembly is only about .030" or .75mm.
This entire assembly less the clutch actuator is spinning at 900-1500 RPM while riding.
Jim
06-17-2009, 11:18 PM
|  | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Ontario, Canada
| | Re: Animated view of the HT Clutch Assembly and countershaft Awesome work Jim!!
I refuse to be taken apart...
06-17-2009, 11:23 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2009 Location: michigan
| | Re: Animated view of the HT Clutch Assembly and countershaft This is a great thread to point people to trying to trouble shoot their engine now you need piston movement and intake /exhaust flow. Wow good job Maniac |
06-17-2009, 11:28 PM
| | Re: Animated view of the HT Clutch Assembly and countershaft Quote:
Originally Posted by Rockenstein Awesome work Jim!! | Thanks Rock!
Jim |
06-17-2009, 11:39 PM
| | Re: Animated view of the HT Clutch Assembly and countershaft Maniac is it ok to copy the gifs and use them when i try to help people out(explain to people something about their circumstance)? I can post something underneath them pointing to you website. |
06-17-2009, 11:42 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Tampa Bay, FL
| | Re: Animated view of the HT Clutch Assembly and countershaft I love it when he does this stuff....
'BrettMavriK |
06-17-2009, 11:53 PM
Originally Posted by reg454 Maniac is it ok to copy the gifs and use them when i try to help people out(explain to people something about their circumstance)? I can post something underneath them pointing to you website. | Reg,
No problem...This was done for the forum.
I'm going to be adding a full text description of the assembly. I have split many of these engines apart, so all I ask is that you do not provide text descriptions that are not accurate. Use the descriptions that I will provide with the gifs, and add your own observations as you gain more hands-on experience.
You may also want to ask the moderators if it is O.K. to use these in a repetitious manner...I don't know if it will bog down threads or cause other problems.
Jim | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:22 PM. | | | Sponsors
