| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Shifter Kits Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. whats the feedback on shifter kits ,sure works cool.I want one.Sick bike parts set up looks nice....  | |
12-17-2008, 10:26 PM
|  | Motorized Bicycle Newbie | | Join Date: Dec 2008 Location: victoria b.c canada
| | Shifter Kits whats the feedback on shifter kits ,sure works cool.I want one.Sick bike parts set up looks nice. |
12-18-2008, 12:18 AM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Las Vegas NV USA
| | Re: Shifter Kits i am very interested in a SBP kit as well looking for right after christmas to purchase but i would like some input as well |
12-18-2008, 02:55 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Asia
| | Re: Shifter Kits Check out this thread: Shifter Kit from www.sickbikeparts.com
I have a shifter kit. It is a very good product. However, you might need to change your bottom brackets. It requires 127mm or longer bottom brackets. You might also find some difficulty in aligning the chain lines. Also, be careful not to loose the key locks, it can slip out if you don't locktite it. I lost one of mine. You also need to paint it, so roughen the surfaces first, use a primer then paint it over with the final finishing paint. Use a heavy duty BMX chain.
You should also have an adequate space between your rear wheel and your seatpost, or install a smaller rear wheel if you have disc brakes.
Before, my Motorized bicycle maxed out 25mph, now it can reach to 44mph in 6th gear.
Engine does not have power anymore after 6th gear. I'm using an 8 speed internal gear hub.There is substantial improvement in hill climbing ability.
Also, Paul is very nice and they give all the support to meet their customers' needs.
__________________ It's more than a hobby, it's my transport. Caution: This hobby is habit forming.
12-18-2008, 07:21 AM
| | Re: Shifter Kits Quote:
| Thanks for the great comments. I can follow up on the above.
Indeed - you should be aware of what style BB (bottom bracket) your bike has. The kit is designed for a standard three piece BB, but will work with most any BB with the correct adaptation. We sell two styles of adapters for one piece, so that's no problem. Technocyclist's bike had a sealed cartridge style, hence his mention of needing a 127mm replacement.
The chain alignment is critical, but not difficult. We definitely recommend Loctite and filing flats on the jackshaft.
The new HD plates all come powder coated with primer now. HD chain is fine, but as long as your current chain is in good shape it will do OK. Spacing and other details are here: Requirements |
12-18-2008, 10:49 AM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: Seattle
| | Re: Shifter Kits Hey Pablo, are you staying warm out there? It's cooolld,d,d here in the metro! |
12-18-2008, 10:51 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: Shifter Kits My suggestion is to toss the cartridge style, for $10 you can get the bearing set to convert to the old 3 piece style. $10 seems cheap to eliminate some of the headaches not converting may cause.
22 degrees up here in Bellingham with about 8 inches of snow, fun drive to work this morning. |
12-18-2008, 11:03 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Shifter Kits Hey Ghost0 and Pablo, do you guys think this chain would be a suitable chain for use with the kit? my bike chain is 10 years old... KMC X8.93 Chain w/ Missing Link 6/7/8 Speed Each Silver / Gray |
12-18-2008, 11:14 AM
Originally Posted by jasonh | If it's the right size, then it should be fine.
I'm stuck at home today. Roads are closed!! My Commute Traffic Cameras - King County Road Services Division |
12-18-2008, 11:22 AM
| | Re: Shifter Kits well that looks like fun, lol. |
12-22-2008, 12:58 AM
|  | Motorized Bicycle Senior Member | | Join Date: Sep 2008 Location: Kelso Wa
| | Re: Shifter Kits Yeah the shifter system was a well I can make one thing but If it gets down to say 160 Id consider it. Oh cold and deep Snow here in Kelso Longview. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:20 AM. | | | Sponsors
