needle clip
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. when you install the throttle into the slider barrel , should the needle clip be above or below the c - shaped ...
Old 07-08-2008, 01:06 PM
filestyle1's Avatar
Default needle clip
when you install the throttle into the slider barrel , should the needle clip be above or below the c - shaped washer? I have run both ways and seems to do fine either way but just looking for a census!
I'll keep rollin "FileStyle"
"I'am just a penny short of being a millionaire"
Old 07-08-2008, 01:33 PM
Pablo's Avatar
Default Re: needle clip
How could it work either way??? The needle could "float" up if not in this order:
See: Motorized Bicycle Carburetor install and rebuild
Old 07-08-2008, 07:14 PM
very nice paul
Old 07-08-2008, 07:45 PM
Pablo's Avatar
I just stole Norman's pictures.
Old 07-08-2008, 07:49 PM
MarkTur's Avatar
Oh...and I thought you were an upstanding individual!
(kidding)
Cya!
Mark Turkel
http://www.AreWeOnline.com
http://www.PalmBeachSoftware.com
HT 70cc ...lots of extras
Kulana Moon Dog Aka BLUE DOG
Like someone else said "Sticking it to the Man!"
Old 07-08-2008, 07:56 PM
Pablo's Avatar
Naw I'm a natural plagiarizer and general clown about town and can be found outstanding in my field. But other than that, I'm a fine and serious dude.
Hey why re-invent the wheel?
Old 07-08-2008, 08:06 PM
MarkTur's Avatar
LOL
Dude, help me out...I richen up my motor, and all of a sudden I can hit 35mph...but my idle is barely running with the screw turned all the way in. 35:1 AMSOil, NGK plug. The low end is HORRIBLE. I moved the clip to the third slot down from the blunt end. It was on the last slot - lean - before, and I had decent low end, but great mid, boggy high.... I know the high end now was too lean, but I guess the way I was riding it (half throttle) it was rich enough to give me a nice brown plug.
I'm actually ready to move on to a better bike and new motor, but don't know what to buy, or who from, and who's got anything in stock. But before I do anything, I want to get my motor right.
I ported both ports like you suggested, so that's no longer any type of bottleneck. I also have an o-ring in the carb to prevent air leaks - but I'm ready to pull it out and let some more in if nobody can give me a better suggestion.
Thanks!
Mark
Cya!
Mark Turkel
Old 07-08-2008, 08:31 PM
Pablo's Avatar
So have you actually ported your engine?
Or just matched the stock exhaust to the port? Or did you get an expansion pipe?
Same with intake? Port/gasket/manifold all match?
Is your engine well broken in? How many full tanks of fuel have you used?
Have your jets arrived? Have you measured your stock jet?
I need a better baseline - because it's quite odd going two clicks rich makes it run better. Especially at WOT.
  #9 (permalink)
Old 07-08-2008, 08:32 PM
Pablo's Avatar
Sometimes the O-ring if too fat, makes it worse.
  #10 (permalink)
Old 07-09-2008, 08:14 AM
Bikeguy Joe's Avatar
MODERATOR
I have found that when I get an optimal full throttle mixture, the bottom end is too rich. Good off idle and mid? too lean at WOT.
I taper my needles to fix that. Not for the faint of heart.....
Advertisers
