Installing a new Magnet.
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I finally got around to getting the parts needed for my other engine and I crazy glued the key for ...
Old 06-18-2008, 10:38 PM
Mopedamauter79's Avatar
Default Installing a new Magnet.
I finally got around to getting the parts needed for my other engine and I crazy glued the key for it in place. However I can't figure out how to get the magnet screwed on properly..I got it partly on and I can't seem to screw it on anymore then it is. Suggestions ?
Old 06-19-2008, 10:03 PM
misteright1_99's Avatar
Default Re: Installing a new Magnet.
I have heard the best way is to out paper between the magneto and armature to keep it aligned. Is this the problem your having? Take a look at this Thread, maybe last few posts will help... I have never had to mess with magneto, so I don't know, just what I read...
Old 06-19-2008, 11:45 PM
fairracing31's Avatar
Are you sure it's not going in all they way? When I first did mine I thought the same thing then realized it was in all the way. There should only be a few thread's left from the nut.
Old 06-20-2008, 12:46 AM
I can't get it in that far at all.There is no thread at all for the nut to go on as the magnet isn't all the way in. I've pretty much given up on this by this point. To much hassle and frustration with it.
I emailed a seller of these engines about how to install that magnet and It sounded complicated for a simple thing.
"You will likely need to either use a press or to use a socket that has thick walls on it and is the same diameter as the inner area of your magnet. Use a hammer to tap it into place with having the socket between the magnet and the hammer…try not to bang on it too much or you could knock the magnetism out of the magnet.
A press would do you best though…just make sure that you have the keyway lined up properly."
Old 06-20-2008, 01:06 AM
Yes, that's how I got mine on. I use a press but I don't need that much force to get it on. Having the keyway lined up is very important! Are you sure your keyway did not move? It might have moved and is keeping it from going on all the way.
Old 06-20-2008, 01:12 AM
It's crazy glueded on. I don't think it moved.
Old 06-20-2008, 01:17 AM
I checked it and the key sticks out. If the magnet is supposed to go over this key then that's not going to happen. The key simply wont sit in flush with the shaft and it stick out
Old 06-20-2008, 01:20 AM
There should be a slot in the mag for the keyway to go into
  #9 (permalink)
Old 06-20-2008, 01:30 AM
how is the key supposed to sit in the shaft ? the keyway does not look large enough for it to pass over the key.
  #10 (permalink)
Old 06-20-2008, 01:33 AM
Is it the original woodruff key?
Advertisers
