Re: HELP! schwinn single speed with back pedal brakes All of the bikes I have built were "coaster" or "back pedal" brakes.
You will need to do a couple of mods to make the kit work, not hard ones either.
Remove the dust cover on the end of the axle and grind off the outer flange of the dust cover. I posted pictures of this somewhere around here...
You will also have to bend the brake arm very slightly to clear the bolt heads.
Alternately, you can bore the center hole in the sprocket, and use countersunk screws to clear the brake arm....the choice is yours.
__________________ If it ain't broke, and you mess with it long enough, it will be.
